*** SOLD***Eunos Roadster B2 1996 At Wayne mansion revamp thread,07***SOLD***
Re: Eunos Roadster B2 1996 At Wayne mansion revamp thread
More....
- 20170212_133057.jpg (494.28 KiB) Viewed 8041 times
- 20170212_133105.jpg (508.92 KiB) Viewed 8041 times
- 20170212_133114.jpg (471.29 KiB) Viewed 8041 times
- 20170212_134134.jpg (453.1 KiB) Viewed 8041 times
- 20170212_134141.jpg (470.18 KiB) Viewed 8041 times
- 20170212_134146.jpg (461.54 KiB) Viewed 8041 times
- 20170212_134223.jpg (345.74 KiB) Viewed 8041 times
- 20170212_134235.jpg (339.57 KiB) Viewed 8041 times
- 20170212_140118.jpg (451.81 KiB) Viewed 8041 times
- 20170212_140123.jpg (427.42 KiB) Viewed 8041 times
- 20170212_140129.jpg (461.33 KiB) Viewed 8041 times
- 20170212_140133.jpg (441.86 KiB) Viewed 8041 times
- 20170212_140545.jpg (444.2 KiB) Viewed 8041 times
- 20170212_140932.jpg (464.56 KiB) Viewed 8041 times
- 20170212_140940.jpg (496.62 KiB) Viewed 8041 times
- 20170212_141552.jpg (397.95 KiB) Viewed 8041 times
- 20170212_141604.jpg (427.82 KiB) Viewed 8041 times
- 20170212_142626.jpg (487.4 KiB) Viewed 8041 times
- 20170212_142632.jpg (451.27 KiB) Viewed 8041 times
- 20170212_142925.jpg (487.9 KiB) Viewed 8041 times
- 20170212_142955.jpg (501.61 KiB) Viewed 8041 times
- 20170212_143214.jpg (457.49 KiB) Viewed 8041 times
- 20170212_143448.jpg (499.92 KiB) Viewed 8041 times
- 20170212_143455.jpg (499.55 KiB) Viewed 8041 times
- 20170212_143503.jpg (467.09 KiB) Viewed 8041 times
- 20170212_153051.jpg (453.35 KiB) Viewed 8041 times
- 20170212_153055.jpg (414.84 KiB) Viewed 8041 times
- 20170212_155055.jpg (474.07 KiB) Viewed 8041 times
- 20170212_155101.jpg (505.4 KiB) Viewed 8041 times
- 20170212_155113.jpg (498.82 KiB) Viewed 8041 times
- 20170212_155127.jpg (526.55 KiB) Viewed 8041 times
- 20170212_160514.jpg (483.92 KiB) Viewed 8041 times
- 20170212_160520.jpg (480.63 KiB) Viewed 8041 times
- 20170212_163824.jpg (462.81 KiB) Viewed 8041 times
- 20170212_163830.jpg (475.06 KiB) Viewed 8041 times
- 20170212_164224.jpg (332.58 KiB) Viewed 8041 times
- 20170212_164237.jpg (360.9 KiB) Viewed 8041 times
- 20170212_164522.jpg (434.08 KiB) Viewed 8041 times
- 20170212_165438.jpg (528.11 KiB) Viewed 8041 times
- 20170212_165443.jpg (517.63 KiB) Viewed 8041 times
- 20170214_200701.jpg (381.76 KiB) Viewed 8041 times
- 20170214_200723.jpg (450.83 KiB) Viewed 8041 times
- 20170214_200712.jpg (478.98 KiB) Viewed 8041 times
- 20170214_200745.jpg (569.34 KiB) Viewed 8041 times
- 20170214_200736.jpg (541.44 KiB) Viewed 8041 times
- 20170214_200727.jpg (474.78 KiB) Viewed 8041 times
- 20170214_173617.jpg (426.23 KiB) Viewed 8041 times
Time to attack the brakes.... even the 10mm wing bolts came out like new.....every nut and bolt is being cracked greased and put back on the whole roadster...
- 20170304_133816.jpg (602.9 KiB) Viewed 7993 times
- 20170304_133820.jpg (362.49 KiB) Viewed 7993 times
- 20170304_133827.jpg (423.76 KiB) Viewed 7993 times
- 20170304_133831.jpg (445.93 KiB) Viewed 7993 times
- 20170304_143650.jpg (514.3 KiB) Viewed 7993 times
- 20170304_143657.jpg (399.43 KiB) Viewed 7993 times
- 20170304_145025.jpg (437.37 KiB) Viewed 7993 times
- 20170304_145031.jpg (423.11 KiB) Viewed 7993 times
- 20170304_145038.jpg (474.59 KiB) Viewed 7993 times
- 20170304_150700.jpg (413.77 KiB) Viewed 7993 times
- 20170304_150707.jpg (468.36 KiB) Viewed 7993 times
- 20170304_164259.jpg (457.73 KiB) Viewed 7993 times
- 20170308_195840.jpg (524.53 KiB) Viewed 7993 times
- 20170308_201705.jpg (467.66 KiB) Viewed 7993 times
- 20170308_220121.jpg (529.71 KiB) Viewed 7993 times
- 20170308_220132.jpg (531.27 KiB) Viewed 7993 times
- 20170308_220204.jpg (516.84 KiB) Viewed 7993 times
- 20170308_220211.jpg (503.68 KiB) Viewed 7993 times
- 20170308_220218.jpg (509.71 KiB) Viewed 7993 times
- 20170308_220238.jpg (456.1 KiB) Viewed 7993 times
Extras items that have popped up..
Someone as replaced the OE front suspension with MK 2.5 Billies(one is bent anyway) so they need to be swapped out for OE MK 1 units, rears are ok, all the boots at the front want doing, upper ball joint,bottom ball joint and track rod ends, and someone in the past had tack welded the rear tail pipe on for the zorst which came away in my hands, also i need to replace the passenger side bottom wishbone as it looks like it as hit a curb at some point and is showing impact stress...
While she is up in the air i only need to replace the fuel filter for the service to be complete..
Undersealing and box sections next and the a engine bay clean..
- 20170308_201722.jpg (515.66 KiB) Viewed 7993 times
- 20170304_164339.jpg (454.82 KiB) Viewed 7993 times
- 20170304_164333.jpg (439.99 KiB) Viewed 7993 times
- 20170304_164324.jpg (467.21 KiB) Viewed 7993 times
- 20170304_164316.jpg (450.81 KiB) Viewed 7993 times
- 20170304_164307.jpg (479.95 KiB) Viewed 7993 times
- 20170308_220142.jpg (441.99 KiB) Viewed 7993 times
- 20170308_220150.jpg (563.06 KiB) Viewed 7993 times
- 20170308_220106.jpg (518.41 KiB) Viewed 7993 times
- 20170308_220110.jpg (583.49 KiB) Viewed 7993 times
Brakes all done...
- 20170309_210048.jpg (458 KiB) Viewed 7985 times
- 20170309_210041.jpg (486.42 KiB) Viewed 7985 times
I know you've had your hands full lately Wayne, but what are the updates in this beauty? Absolutely love this car.
1. A car is only worth what someone is willing to pay for it, 2. Resale wont save your life in an accident, 3. Genius has limits, stupidity has none, 4. Never argue with an idiot, they will bring you down to their level & beat you with experience, 5. Growing old beats the alternative -- dying young!
Engine bay clean,fresh oil and filter, new fuel filter,, passenger bottom wishbone(don't like the one that is on), front OE dampers complete as some numpty as fitted Mk 2.5 billies to the front only???,A better zorst as someone had co*ked up the one thats on,full underseal and box sections, screen out (chip in it) and full hit of paint( not happy with it ,if i am doing it then it needs to be done all correct plus i have fitted a new rear bumper which is black at the minute and front splash guards, and refurb rims or fit some BBS rims?
And then she is finished.
Zorst ,dampers and wishbone was kindly lent from mat russel x
I will up date as i go, all will be shown, nothing to hide, someone will get a great Mk1.
Ok update for you.....
Engine bay cleaned, passenger bottom wishbone swapped out and front suspension to OE MK 1 units...zorst fitted...
- 20170415_110158.jpg (606.11 KiB) Viewed 7909 times
- 20170415_110208.jpg (570.78 KiB) Viewed 7909 times
- 20170415_110217.jpg (577.1 KiB) Viewed 7909 times
- 20170415_110221.jpg (541.45 KiB) Viewed 7909 times
- 20170415_110229.jpg (557.89 KiB) Viewed 7909 times
- 20170415_110234.jpg (563.86 KiB) Viewed 7909 times
- 20170415_110248.jpg (531.18 KiB) Viewed 7909 times
- 20170415_110253.jpg (563.74 KiB) Viewed 7909 times
- 20170415_110309.jpg (542.98 KiB) Viewed 7909 times
- 20170415_110315.jpg (562 KiB) Viewed 7909 times
- 20170415_110336.jpg (629.66 KiB) Viewed 7909 times
- 20170415_135627.jpg (464.22 KiB) Viewed 7909 times
- 20170415_135651.jpg (461.24 KiB) Viewed 7909 times
- 20170415_135656.jpg (675.03 KiB) Viewed 7909 times
- 20170415_135706.jpg (471.91 KiB) Viewed 7909 times
- 20170415_144258.jpg (718.1 KiB) Viewed 7909 times
- 20170415_144309.jpg (421.69 KiB) Viewed 7909 times
- 20170415_144314.jpg (505.59 KiB) Viewed 7909 times
- 20170415_144323.jpg (635.79 KiB) Viewed 7909 times
- 20170415_144331.jpg (562.41 KiB) Viewed 7909 times
- 20170415_151745.jpg (467.68 KiB) Viewed 7909 times
- 20170415_151751.jpg (508.64 KiB) Viewed 7909 times
- 20170415_151757.jpg (471.28 KiB) Viewed 7909 times
- 20170415_151813.jpg (502.46 KiB) Viewed 7909 times
- 20170415_161041.jpg (669.28 KiB) Viewed 7909 times
- 20170415_161052.jpg (464.05 KiB) Viewed 7909 times
- 20170415_173132.jpg (395.58 KiB) Viewed 7909 times
- 20170415_173138.jpg (501.16 KiB) Viewed 7909 times
- 20170417_195737.jpg (450.47 KiB) Viewed 7909 times
More....
- 20170415_102739.jpg (579.74 KiB) Viewed 7908 times
- 20170415_102733.jpg (368.52 KiB) Viewed 7908 times
- 20170415_102720.jpg (436.54 KiB) Viewed 7908 times
- 20170415_102713.jpg (456.3 KiB) Viewed 7908 times
- 20170415_102706.jpg (595.63 KiB) Viewed 7908 times
- 20170415_102658.jpg (575.29 KiB) Viewed 7908 times
- 20170415_102652.jpg (584.28 KiB) Viewed 7908 times
- 20170415_102647.jpg (567.49 KiB) Viewed 7908 times
- 20170415_102642.jpg (574.54 KiB) Viewed 7908 times
- 20170415_102635.jpg (561.16 KiB) Viewed 7908 times
- 20170415_102629.jpg (485.99 KiB) Viewed 7908 times
- 20170415_102623.jpg (569.62 KiB) Viewed 7908 times
- 20170415_102615.jpg (559.63 KiB) Viewed 7908 times
- 20170415_102608.jpg (554.61 KiB) Viewed 7908 times
- 20170415_102602.jpg (588.29 KiB) Viewed 7908 times
Fresh oil, oil filter, fuel filter and diff oil done...
- 20170418_191200.jpg (466.23 KiB) Viewed 7902 times
- 20170418_191214.jpg (562.56 KiB) Viewed 7902 times
- 20170418_191209.jpg (461.28 KiB) Viewed 7902 times
Cleaned and undersealed.....
- FB_IMG_1493012417326.jpg (411.79 KiB) Viewed 7881 times
- FB_IMG_1493012422602.jpg (315.81 KiB) Viewed 7881 times
- FB_IMG_1493012426558.jpg (345.01 KiB) Viewed 7881 times
- FB_IMG_1493012430447.jpg (355.86 KiB) Viewed 7881 times
- FB_IMG_1493012434611.jpg (338.73 KiB) Viewed 7881 times
- FB_IMG_1493012438435.jpg (309.38 KiB) Viewed 7881 times
- FB_IMG_1493012442336.jpg (329.01 KiB) Viewed 7881 times
- FB_IMG_1493012447740.jpg (334.87 KiB) Viewed 7881 times
- FB_IMG_1493012451657.jpg (395.48 KiB) Viewed 7881 times
- FB_IMG_1493012454991.jpg (338.75 KiB) Viewed 7881 times
- FB_IMG_1493012458558.jpg (379.81 KiB) Viewed 7881 times
- FB_IMG_1493012462691.jpg (218.73 KiB) Viewed 7881 times
- FB_IMG_1493012466696.jpg (361.09 KiB) Viewed 7881 times
- FB_IMG_1493012470097.jpg (321.73 KiB) Viewed 7881 times
- FB_IMG_1493012473706.jpg (320.17 KiB) Viewed 7881 times
- FB_IMG_1493012479013.jpg (327.9 KiB) Viewed 7881 times
- FB_IMG_1493012482897.jpg (371.18 KiB) Viewed 7881 times
- FB_IMG_1493012486510.jpg (281.25 KiB) Viewed 7881 times
- FB_IMG_1493012490980.jpg (349.54 KiB) Viewed 7881 times
- FB_IMG_1493012495545.jpg (360.37 KiB) Viewed 7881 times
Gear selector changed with new bushes and selector cover indicator....
A very nice man found me some better bits to use and sent them Thank you Andrew... Autolinkmx5... so I made up the best from two units.
I changed this so i know it's right, and would love her to stay as a Auto from being built at the factory, but will be offered as a manual also when finished to the new owner if wished at a extra cost.
Well the decision as been made... she will be converted to a 5 spd manual, with lightened fly wheel and lsd, as per factory spec.
Will do a full "how to convert guide" as i go for others to use as there is a lot of crap and myths and what to change and use out there, it's not as hard as you think.
Mazda Mender wrote:Well the decision as been made... she will be converted to a 5 spd manual, with lightened fly wheel and lsd, as per factory spec.
Can't wait. So interesting!!!!
Also can't believe how you get your engine bay so clean!!
Mazdamendera JiĹşza clean buddy.
Users browsing this forum: No registered users and 22 guests
