Members and searchers please be aware that some of our 'how to' guides do not currently show the intended help photos. This is because photobucket wants to charge a monthly amount for us to view our own pics. The photos are currently being replaced. If you need one of our guides and it is missing pics please let one of the Admin team know and we will make that one a priority for you.
Mk1 restoration
Mk1 restoration
Postby John&Luke » Sat Dec 09, 2017 10:17 pm
Hi, so starting my next restoration project.
Managed to get my White Mk1 into the garage today ready to start a few months swearing, cursing, spending far to much but, hopefully getting there in the end.
Couple of photos to set the scene.
Jobs will include, new sills /arches, new wings, straighten the drivers door were its be closed against the seat belt :naughty: bodywork before respray, and interior make over.
Target Summer Rally :?:
Look forward to menders advice and encouragement. I will need it!
A real menders project>
Re: Mk1 restoration
Postby Mazda Mender » Sun Dec 10, 2017 11:15 pm
:text-goodpost: :coffee:
Mk 1 Eunos 93 black V.S II 1.8 fettling,
Mk 1 Eunos 96 1.8 blue B2...being fettled
Mk1 Eunos 93 1.6 black S special **gone**
DavesBRG5
Re: Mk1 restoration
Postby DavesBRG5 » Mon Dec 11, 2017 2:30 pm
Always worth saving the white ones......Keep us posted :text-goodpost:
Still need a decent white passenger wing for mine if you come across one.
DAVE
1992 ROADSTER 1.6 Tanabe Sustec suspension, Cusco bracing, Momo Prototipo steering wheel, Mike Satur TT Hoops, Jass Performance interior bling.
Re: Mk1 restoration
Postby John&Luke » Sat Dec 30, 2017 2:22 am
Hi Menders, Merry Christmas to everyone.
Little update on my latest project. Managed to get some time today to start the process of removing the rot.
On first inspection the arches don't look to bad.
However as we know, its what you can't immediately see that can be the problem. A good inspection underneath showed the effect of a poorly applied underseal. Its formed a second skin that has delaminated from the metal and formed a prefect water trap leading to a a completely rotten inner sill. I could literally pick off the underseal in big chunks.
So more that I bargained for. But a 2 owner 50k miler has got to be worth some effort?
Front wing is also a goner, inner wing wire brushed and rust treated ready for a decent Upol primer.
Re: Mk1 restoration
Postby Mazda Mender » Sat Dec 30, 2017 9:27 pm
:text-coolphotos: :handgestures-thumbup: :coffee: :coffee: :coffee:
Re: Mk1 restoration
Postby John&Luke » Wed Jan 03, 2018 11:02 pm
Update on progress made. Door and rear bumper removed, typical issue with the 8 off 14mm bumper retaining bolts in that one started spinning (luckily the one of the bottom ones) and had to be cut off, and two snapped the retaining bolts due to corrosion. Door was less problematic.
In between times, the inner wing was wire brushed and de rusted, rust treated, and etch primed.
Moving back to the rear arch, the bottom section is gone and needs replacing.
and whilst the inner wing looks not to bad, after a more detailed inspection it also needs replacing. To just clean this up and rust treat would be a false economy in my opinion. see photos below
So a complete re-fabrication, which should make spot welding the replacement wing in place straightforward at least :-D
To fabricate the inner wing I'm using 25mm angle section, which I cut into manageable lengths. A metal shrinker/stretched is invaluable for forming the necessary curve of the arch. So starting at the bottom I made the most difficult bit. I purposely have made the return flange to wide at this stage so I can trim to the inner and outer arch profile to match (see drawn line).
Once this section was made (about 2 hours work) as this needed cutting and welding to get the tight radius) I moved on to the next section. Here you can see this clamped in place. The stretcher being used to stretch the upright flange of the angle and hence form the main curve of the arch. Note the 4 cuts on the return flange in order to follow the inward radius of the arch. These will be welded together once finished.
More of the same for the third and fourth section.
and then a trial fit of the new inner sill.
A good days work for me, not to many mistakes and a sense of achievement :coffee:
Next step will be to finish the last section of the inner arch and then cut out the old and start the welding.
As always, please if anyone spots any issues or mistakes please reply and let me know!!!!!
fujikun
Re: Mk1 restoration
Postby fujikun » Thu Jan 04, 2018 9:10 am
:text-goodpost:
Brgdane
Re: Mk1 restoration
Postby Brgdane » Sun Jan 14, 2018 5:04 pm
Lovely job
Users browsing this forum: No registered users and 5 guests
