Help!
My 5 failed it's MOT yesterday, the ABS light does not come on when you first turn the ignition on.
I have spend a few hours testing things but my multimeter has broken. I will pick up a new one and test more tonight.
I have tested so far:
1. Bulb works - I have tried 3 or 4 working bulbs and holders to confirm
2. Power to one side of the bulb from the 'ign' side of instrument cluster
3. When using a test lamp between the 'ign' (blk/yel) wire which is powered with ignition on and the 'ABS' (blu/yel) wire, the test lamp does not illuminate.
My two current guesses are:
1. Faulty ECU that does not send the signal to the instrument cluster
2. Faulty wire (blu/yel) from ECU to instrument cluster.
Can anyone shed some light on this or at least advise what I can test to narrow this down some more?
Thanks,
Adam
ABS Light does not come on
Re: ABS Light does not come on
Just to add to this, the car is a MK1 1997 1.8
Sorry bud but auto electrics are not my scene, but hang on in there as the top dogs will still be out there mending
Have you tried another earth to that bulb connection on the cluster.
I set out to the garage armed with a functioning multimeter last night. Tested to make sure I had power to and from the ABS control unit and checked the ABS wire to the instrument cluster (blu/yel) was switching the earth as it should - no issues found.
Next removed the instrument cluster and put a test lamp across the ABS bulb circuit - we have light - a fault in the printed circuit board is the culpret. I jumped on to instagram and found someone 14 miles away with a spare instrument cluster and now all my troubles have gone away
Thank you for your comments, let's hope its still working at the re-test next week
Adam
Adam
Users browsing this forum: No registered users and 17 guests
