Hi,
NA Eunos 1995 with a later roof fitted with heated rear window. The existing HRW wiring uses an aftermarket rocker switch and a separate run of wiring with a relay and it's a bit of a dog's dinner tbh (not installed by me). I'd like to try and use the existing wiring so that I have a light on the dash and a timer etc. I've pulled the existing switches and wires and I now need to confirm that the white plug in the attached pic is for the push / push type switch (NA7566460)
Also, what is the black connector block in the pic supposed to be for?
Thanks in advance
Push Push Switch connector for heated rear screen?
- Attachments
- screen.jpg (13.43 KiB) Viewed 4839 times
Re: Push Push Switch connector for heated rear screen?
Yak wrote:Hi,
Thanks in advance
It is all plug and play on your 95 version,,,,picture is blank?
I'll try the pic again
- Attachments
- IMG_20191006_165745_DRO.jpg (607.28 KiB) Viewed 4828 times
Ah, so the white one is for the HRW and the black for electric door mirrors (which I don't have). Just need to get the single HRW push type switch from Autolink, put the wiring back to normal and sort a pigtail for the HRW then. Cheers
If you get stuck just shout buddy.use the discount code off here for Autolinkmx5.
Finally got it done, ripped out the additional wring and relay and fabricated some leads to use the rocker switch with the original plug. Made a pigtail using the instructions on here and now it works. A lot tidier and I even have the dash light as well.
Thanks
Thanks
Users browsing this forum: No registered users and 15 guests
