Mk1 fuse blow
Mk1 fuse blow
My mk1 has started blowing 10a fuse that affecs indicaters rev counter and gauges. It's intermittent. Any advice?
Re: Mk1 fuse blow
It's a short somewhere,do you have anything aftermarket fitted? but check the bulbs, i have had that before ,a short through a bulb, but it could also be the stalk?
Re: Mk1 fuse blow
No after market except I updated the headline bulbs a year ago it only started happening in June and then randomly. Which of the bulbs would you suggest I look at ?
Re: Mk1 fuse blow
Only aftermarket figment are updated headlight bulbs a year ago this started in June and since randomly
Re: Mk1 fuse blow
Try going around the indicators one at a time to see which if any is blowing the fuse, what i meant by "aftermarket" anything added into the wiring, aram? Etc extra bulbs, indicators??? etc.
Re: Mk1 fuse blow
Been round the bulbs all seem dry and nothing looking untoward.are you suggesting looking at the indicator stalk for something loose etc?
Re: Mk1 fuse blow
You are testing for an electrical fault, so go around the indicators one at a time, remove the bulb and indicate , if it does blow , put the bulb back and onto the next one until you have remove all to find the one giving the issue, when it sops blowing a fuse, it might blow after testing them all, which means the fault is else where, but you need to rule these out first to move on with the search, just a look is not testing buddy, if you are looking for a quick answer to the fault across the internet with a electrical fault it not going to happen, it needs to be done in steps.
Users browsing this forum: No registered users and 12 guests
