Postby Mazda Mender » Wed Dec 25, 2019 8:56 pm
Gauge is all wired in and connected up under the bonnet and is running it start up with ignition and working spot on to show the real operating coolant temp for the cooling fans to kick in and show a 10 degrees true drop for the fans to stop and the cycle start again while the OE one does "nothing"...
All the last bits tided up , the HU is not talking to the electric aerial, now whether it is the HU or a damaged wire to the aerial ???? as i have tested with a spare known working aerial and nothing from the signal wire????Personally i would just fit a stubby aerial and be done with it and be done with the hassle....
Suspension next now....
- IMG_20191224_133235.jpg (600.22 KiB) Viewed 8557 times
- IMG_20191224_133239.jpg (506.32 KiB) Viewed 8557 times
- IMG_20191224_135555.jpg (507.04 KiB) Viewed 8557 times
- IMG_20191224_135559.jpg (495.88 KiB) Viewed 8557 times
- IMG_20191224_140606.jpg (445.36 KiB) Viewed 8557 times
- IMG_20191224_140609.jpg (424.54 KiB) Viewed 8557 times
- IMG_20191224_140614.jpg (383.64 KiB) Viewed 8557 times
- IMG_20191224_140657.jpg (454.79 KiB) Viewed 8557 times
