If you have found this guide useful or any of the others, and as saved you on garage costs , please drop a donation to the site, what ever you it maybe, to help keep her open and running for others to use also, many many thanks.....
I have had a number of owners getting in touch about the interior light only working form just one door being opened, drivers or passenger side ,so I thought I would do a quick guide. Its a simple and easy fix: the door switches work on making an earth circuit to make the light work, so its just down to a clean from tarnishing...
You will need ....
1 x medium phillips driver,
1 x small flat driver,
1 x small file,
1 x sand paper,
1 x contact cleaner...
*** PLEASE NOTE THAT CLICKING ON THE PICS WILL ENLARGE THEM FOR BETTER VIEWING***
Open the door of the problem side and get the phillips driver and remove the phillips head screw that holds the switch to the B post and put it somewhere safe to be reused....
Then pull the switch from out of the post...
Find the tap in the centre of the connector, and press firmly down an pull to release it from the switch......
As you can see clearly , the tarnishing is bad and stopping a good earth contact....
Find somewhere nice to work and we need to pull the switch apart, start by pulling out the male spade connector. This will just pull free from the plastic and the shaft and spring can be dropped out of the front of the switch body....
Now it is just a case of cleaning the pick ups on the body of the switch, along the top and on the end, with the small screw driver, small fill or sand paper....
Now clean the male spade connector, not forgetting the sides where connection is made....
Once all clean, re insert the spring, shaft and press them in to then press the male connector back into place...
Spray some contact cleaner into the wiring looms female connector at the door pillar and leave to dry; once dry push the female connection back onto the male on the switch...
Offer the switch back into the b post pillar hole, get the phillips head screw and driver and screw it all back into place solid again....
And thats it done, do the other side while all the bits are out.
As always ,any questions , please ask , its what the forum and we are her for.
Cleaning the interior light pillar switch
Postby Mazda Mender » Tue Mar 12, 2024 7:38 am
Jump to
- The Board Room (Administration)
- Mazdamenders.net donation button
- Contact Us
- The Reception (General)
- Welcome desk
- Rules & Regs
- Forum How Tos
- MazdaMenders Shop...of all things great
- Promotions and special offers
- The technical Help desk
- Problems
- The Show Room
- Members Mx-5/ Roadsters
- The Waiting Room
- Mx/Roadster Chat and Banter
- ARCHIVE:- Mx/Roadster Chat and banter
- Non Mx/roadster general car topics
- ARCHIVE:- General car topics
- General chat and banter
- ARCHIVE:-General chat & banter
- Birthdays and general well wishes section
- Chuckle Box
- RANT! Not for the faint hearted!!!
- ARCHIVE:- Rant topics
- FaceBook links
- The Information pin board
- Mazdamenders.net Tech days
- Events & meets
- ARCHIVE:Event topics
- Games & competitions
- Site News
- Our aim and goals....
- Mazda Recalls/call backs/warnings
- The Service Department (Hands On)
- Maintenance
- MK1 -1989 > 1997 (NA)
- MK2/2.5 - 1998 > 2000/ 2001 > 2005 (NB)
- MK 3/3.5 2006 > 2015 (NC)
- Mk 4, 2015 to date (ND)
- Auto's ....all marks 1989 to date
- Modifications
- MK1
- MK2
- MK3
- Auto's
- Your mods
- recommended tools/ must haves/bargains
- The Body Shop Department
- Deepcar Autobodies..... sheffield
- General Body shop
- Cleaning & Detailing
- The Tuning & Boosting Department
- Rolling Road (Extra boost, POWER )
- Superchargers
- Turbo chargers
- Mazdamenders you tube channel
- Mazdamenders you tube channel..
- You tube tech/guide vid links
- You tube racing Vid links
- You tube car stuff vid links
- You tube funny/stupid/miscellaneous vid links
- The Workshop servicing manuals (How To's & FAQs)
- MK 1 1989 to 1997 ( NA)
- Interior
- ICE(audio) and electrics
- Audio(Head units) and speakers
- Electrics
- Trim
- Exterior
- Engine....1.6/1.8 SNC/LNC, transmission and electrics
- Engine
- Transmission and drive train
- Electrics
- Exhaust
- Clutch
- Handling,steering, suspension, wheels,Tyres
- suspension
- steering
- Wheels and tyres
- Braking
- Soft top/Hard top/windows
- Lights and eletrics
- Body panels and accessories
- Maintainence/servicable items
- Heating and cooling
- Mk 2/2.5 1998 to 2005 (NB)
- Interior
- Trim
- Electrics
- Exterior
- Engine....1.6/1.8 ,transmission and electrics
- Engine
- Transmission and drivetrain
- Electrics
- Clutch
- Handling,Steering,Suspension,Wheels,Tyres
- Suspension
- Steering
- Wheels and Tyres
- Braking
- Soft top/ Hard top/windows
- Lights and Electrics
- MK 3/3.5 2006 to 2015 (NC)
- Interior
- Audio(Head units), speakers and Electrics
- Audo and speakers
- Electrics
- Trim
- Exterior
- Engine 1.8/2.0, Transmission and Electrics
- Engine
- Electrics
- Handling, Steering,Suspension,Wheels,Tyres
- Suspension
- Steering
- Wheels and Tyres
- Braking
- Soft top/Hard top
- Miscellaneous (NA/NB/NC/ND)
- Identifying the differences between the most common parts.
- Catastrophic Chris's Poorly Mx-5/Roadster problems
- Top Tips
- NA,NB,NC,ND specs and versions 1989 to date
- JDM NA,NB,NC,ND specs/versions 1989> to date
- JDM MK 1 NA Eunos Roadster Specs 1989 > 1997
- JDM Mk 2 NB Roadster specs 1998 > 2000/01
- JDM Mk2.5 NBFL Roadster specs 2001 > 2005
- JDM MK 3/3.5/ 3.75 NC specs 2006 > 2015
- JDM MK 4 ND specs 2016 to date
- UK Mx-5 NA,NB,NC,ND specs/versions 1990 to date
- UK Mx-5 Mk 1 NA specs 1990 > 1997
- UK Mx-5 MK 2 NB specs 1998 > 2000/01
- UK Mx-5 Mk 2.5 NBFL Specs 2001 > 2005
- UK Mx-5 Mk 3/3.5/3.75 NC specs 2006 . 2015
- UK Mx-5 Mk 4 ND specs 2016 to date
- U.S Miata NA,NB,NC,ND specs/versions to date
- U.S Miata Mk 1 NA specs 1998 > 1997
- U.S Miata MK 2 NB specs 1998 > 2000/01
- U.S Miata MK2.5 NBFL specs 2001 > 2005
- U.S Miata MK 3/3.5/3.75 specs 2006 > 20015
- U.S Miata MK 4 ND specs 2016 to date
- Miscellaneous (NA/NB/NC/ND) brochures form around the world
- Test driving
- Track / Racing
- ARCHIVE:- Track / Racing
- Accessory Catalogues
- Jass performance
- Matthews accessory corner
- Mx5 Tech
- Mx5.fixes.com
- Binarypunk mods & products
- Mazda Bongo
- Miscellaneous Co's of interest
- Traders Section
- Autolink
- Goodwood Sports Cars
- Stokes of kelsey
- Furious fives
- Classifieds
- Auto jumble
- Items For Sale
- Mazda Menders bat cave clear out
- Wanted
- The forecourt (Mx-5/roadsters)
- The swap shop
- Parts Department
- Autolink specials.........
- Insurance
- Adrian Flux Insurance
- The Toilets
- Sin Bin
- Stupid questions and threads archive
- The spotted threads
- The Breakdown help desk
- Mazda-Menders Mx-5 5th Emergency service Volunteers for Mx/roadster owners,,,,
- Feedback Box
- Your Suggestions
- ARCHIVE:-Suggestions
- Complaints Department (Site Problems)
- ARCHIVE:-Site problems
