Hoodedreeper's Mk1 The Purple Monster
hoodedreeper
Re: Hoodedreeper's Mk1 The Purple Monster
Postby hoodedreeper » Wed Oct 29, 2014 4:50 pm
I know there are still some parts dirty,but I was too excited to get it back together and take photos!
A MASSIVE thank you to AutoDoc and H&S Performance for their incredible work!
hoodedreeper
Postby hoodedreeper » Wed Nov 19, 2014 5:07 pm
A small update :)
I wasn't too keen on the BMW Sparkling Graphite painted rocker cover,it looked too dark against the black Inlet Manifold and the front cross over pipe for the air box. So I sent the spare over to a local Powder Coaters. I got it back at the beginning of the week and fitted it today
I also fitted a Polished Plug Cover,both work really well :) I also took a visit back down to H&S Performance who helped me fit a Stoney Racing Ancillary Hose Kit. These guys have been incredible the past couple of months and I cant thank them enough.
I have absolutely no idea what the colour of the purple is. I originally asked for Candy Purple (but they only do basic Candy colours). He said he can do Cadbury's Purple,but this looks very pearlescent in direct light.
Noobie error,i forgot to clean the threads for the front oil breather hose and Coil Pack,so those aren't currently bolted down
Moderator Wannabe
Postby flea » Wed Nov 19, 2014 5:19 pm
lookin good :handgestures-thumbup:
nedski
Postby nedski » Wed Nov 19, 2014 10:08 pm
:text-goodpost: looking great.
Postby Mazda Mender » Wed Nov 19, 2014 10:59 pm
Purple one looks loads better Chris.
GlennyGills
Postby GlennyGills » Fri Nov 21, 2014 1:35 pm
How did you get your coolant bottle so clean ? I have taken mine off and scrubbed with Hairy Liquid and even used a descaler solution. Still black.
My now ex '96 Gleneagles MeisterR Coilovers - engine bling stainless mx5parts full exhaust
Postby Mazda Mender » Fri Nov 21, 2014 1:41 pm
GlennyGills wrote:How did you get your coolant bottle so clean ? I have taken mine off and scrubbed with Hairy Liquid and even used a descaler solution. Still black.
Take it off and use a good strong bleach, and just leave it to do the do and just wash it all out.Major cases of dried on ...sh*t ,i use acid :-D :wink: .
hoodedreeper
Postby hoodedreeper » Sun Dec 07, 2014 8:43 pm
Heres a little video for you (PLEASE WATCH)
https://www.youtube.com/watch?v=NUHq21QhaNE
This has been extremely difficult to keep secret for the past 11 months!!
It all started back in January when i was at Autosport International. I was surrounded by Forced Induction on the MX5Nutz Club Stand,staring at the display of Turbo and Supercharged cars for 3 days started the urge.
At the time,the Interior was booked in to be done in March,and aesthetically the car was pretty much done which only left the engine bay. Having gone the Turbo route with the previous MX5,i thought i'd head down the other path and try out a Supercharger.
So it seems the Eaton M45 from a Mini Cooper S was the popular choice to fit,so the search for one began. Having just missed one on eBay that had covered 25k and being the later generation with teflon blades,it went for £450 delivered. At least i knew this was the kind of money region i was looking at for a unit.
Then i happened to stumble across a For Sale advert on Facebook for one. I dont think i could have sent a message to the seller quick enough! After a few messages back and forth,i had managed to secure myself a Charger that had only covered 19 delivery miles (yes,you did read that correct). It was removed due to a damaged pulley,which by looking at the photos was some-what repairable anyway. Included was a second throttle body with blanking plates and dual cable throttle wheel,all for the sum of £140.00 delivered!
Amongst the vast amount of research i found Aran and Taffylude's build threads on Nutz,who both kindly documentated everything including where to buy it and the costs. This was the perfect Guide for a novice like myself! Massive thanks to them both!
So i took the Charger to work to give it a good clean,removing the PTO and making a blanking plate. At this point i also cut the mounting lug off and blanked the breather port next to it.
RX8 420cc Injectors purchased,these worked great on the turbo build and will help give me some extra ponies. These were sent off to BLiNK Motorsport to be cleaned/flow tested/new seals. They did an incredible job and had a very fast turn around,highly recommend them!
AEM Wideband from Dan at Fast5
As the weather was good,i got some painting done. I wanted a pretty basic looking engine bay,almost OEM,so i went for the classic Wrinkle Black finish. I ended up painting the Inlet Manifold,both Throttle Bodies,Radiator Slam Panel,Wiper Scuttle Panel and Thermostat Housing. Sadly i've only got a photo of the Throttle Body at the time (the rest can be seen in the engine bay photos above)
TR Lane Kit ordered,this was one of the most expensive items and took approx 6 weeks to be made.
It didnt matter that the original pulley was damaged as it was being replaced with a smaller one. I went for a 15% reduction as i wanted it reliable and i had read smaller pulleys could lead to potential belt slip. I ordered one along with a modified By-Pass Valve from 1320.co.uk
I knew removing the pulley was going to be a major task,so i left that in the capable hands of an Engineering company around the corner from mine. It took them a few days to do,but it came off clean which is the main thing
I made some gaskets for the TR Lane inlet and outlet and bolted them together. The charger received a coat of Wrinkle Black paint too
hoodedreeper
In the mean time i was getting ready for the engine bay work to be done,which saw alot of new gaskets and bits and pieces ordered,aswell as new nuts,bolts and washers for various things for the build. Luckily i got majority of the parts from MX5 Parts when they had their discount on!
This then brings me to last week,i had booked the week off so i could fit it. With the turbo build i had to get alot of help from various people as i was pretty clueless with what to do and how to fit it.
I managed to fit the kit on my own! Doesn't sound alot to most,but its pretty achievable on my part (yes,i admit i had to get a second opinion on a few bits,but i'd rather be 100% sure!)
Here are some various photos from the fitting stage:
Radiator Fan moved into the centre,brackets made and the fan wiring extended
Intercooler Pipework Mock Up (Driver's Side)
Manifold removed to fit the Wideband Sensor (its at a stupid place and was easier to remove the Manifold)
I got the Charger mounted in the Engine Bay (knowing it would need adjusting at a later date). Also got the Tensioner Bracket on and the Intercooler all plumbed in
Nice and Stealthy!
hoodedreeper
Postby hoodedreeper » Sun Dec 07, 2014 8:45 pm
IAT and Idle Speed Valve hose fitted to the Intake hose
RX8 Injectors Fitted (after several issues with a crushed O-Ring!)
Belt fitted and tensioned. Air ducting and Pipercross Foam Filter fitted too. Megasquirt 2 V3 had also arrived and was fitted
And there we have it! Supercharged in 7 days :)
nedski
Postby nedski » Mon Dec 08, 2014 10:39 am
:obscene-drinkingcheers: lovely
jonXS
Postby jonXS » Mon Dec 08, 2014 12:01 pm
Winner. The car looks great, and sounds great too.
Might need to scratch the supercharger itch sometime [SMILING FACE WITH SMILING EYES]
Postby Mazda Mender » Mon Dec 08, 2014 9:35 pm
Well done buddy. :handgestures-thumbup: :coffee:
JakeD
Postby JakeD » Mon Dec 08, 2014 10:30 pm
Love the whine from the s/c. Good work on the diy fit, don't think I'd know where to start! Performance to match the styling now :auto-layrubber:
hoodedreeper
Postby hoodedreeper » Sat Dec 13, 2014 3:12 pm
BMW E36 Variable TPS and the adaptor plate from Cerberus
Fitted some Purple LEDs to the RevLimiter Stirling Gauges
I took the car to have a Power Run to see what she's producing
Here is a short video i put together
https://www.youtube.com/watch?v=xEg6vRTBcTs
181.7bhp
164.4lbft
Hoping to get some more mapping done early 2015 to smoothen out the AFR,hopefully should see a increase in power too :)
Users browsing this forum: No registered users and 52 guests
