Pete Can't Open his Bonnet
Catastrophic Chris is a real MX5/Roadster enthusiast and as such owns all version of the car. He's also incredibly unlucky with his cars which suffer from just about every ailment we have come across (and a few we haven't - yet). With your help we can keep all his cars on the road and the smile on his face so please come in and see if you can help.
THESE ARE COMMON AND GENUINE PROBLEMS WITH REAL ANSWERS - WELL WORTH A READ
MrChrome
Postby MrChrome » Fri Dec 07, 2012 9:23 am
Poorly Pete just rang and said his bonnet on his Mk2 won't open.
He says it was fine yesterday but when he got home it wouldn't open.
Any ideas?
Now at DoctorMX5...
Andrew
Site Sponsor
Re: Pete's Can't Open his Bonnet
Postby Andrew » Fri Dec 07, 2012 9:27 am
Sounds like it may have been pushed a bit out of line, get someone to pull the release lever while you pull & push on the bonnet.
Failing that, cut a hole in the front bumper and get the crowbar out ;-)
Regards.
Andrew
www.autolinkmx5.com
Speedy
Epic Poster
Postby Speedy » Fri Dec 07, 2012 9:29 am
Put a rope onto the bumper, tie other end to the gate, stick it in reverse and give it a pull out !!!!
1989 Fresh import with 30,000 km, Maruha Four Pot calipers, 270mm disks, Rose jointed drop links, Uprated ARB's, MeisterR CRD Coilovers, Rota wheels, LSD, Zoom console, Maruha Alternator, Jenvey ITB's, Megasquirt ECU
1st Modified Class Bristol OC Spring Rally
2nd Weston Park April 2017
1st 'Modern Classic' Stafford Castle Classic Show July 2018
3rd 'Best Japanese Classic' Tatton Park Aug 18
1st Modified Class Ragley Hall OC National SEP 18
1st Easter show Weston Park 2019
2nd 80's class Newport Easter show 2019
Postby Mazda Mender » Fri Dec 07, 2012 11:44 am
well in answer to your question i have personally found that simply putting the hook end of a bungie cord strap onto the pull release in the cab, and depending on just how long the cord strap is either hook the other end to the door pillor lock or a spoke on the back wheel (see pic for ref) .
This method is used if you are on your own with no one to pull the bonnet release lever in the cab
MrChrome
Postby MrChrome » Fri Dec 07, 2012 12:14 pm
That's the best "How To..." I've seen in ages!!!! :text-coolphotos:
Now at DoctorMX5...
Return to “Catastrophic Chris's Poorly Mx-5/Roadster problems”
Users browsing this forum: No registered users and 8 guests
