My 91 us special BRG rolling resto
Re: My 91 us special BRG rolling resto
Yes, great Mazda Mending, more power to your elbow BRGdane!
2008 Mk3 Copper Red gone
2018 Mk4 GT+ Red
2018 Mk4 GT+ Red
Thanks guys !
Just the nod I needed, spend all day working on the green beast.
A pillars welded, finished rear inner wheel wells.
Started dismantling and prepping for paint.
Got instant help 2 times today on Menders FB page. Couldn't have solved the task without your great support ;-)
We are everywhere ;0)
Hi brgdane,
Been reading your resto from the beginning and hats off to you mate your doing a great job in cold conditions. I love reading stuff like your resto gives us all the will to keep our olduns going.
Well done and keep writing and posting. p.s hows the dog?
Thanks Fuji,
Still mending
Epoxy done
Still mending
Epoxy done
And the dog is doing fine
Hi Brgdane, what spray set up are you using? ie. what kind/size compressor and spray gun are you using?
[IMG]https://uploads.tapatalk-cdn.com/20170917/fb3c854975aef072617c53541d897d60.jpg[/IMG]
[IMG]https://uploads.tapatalk-cdn.com/20170917/9d28a55a775951443d13b230a1fa8e74.jpg[/IMG]
I use this compressor and this tiny aircleanser/water trap.
I have a better air cleaning solution in the pipeline.
Not an ideal setup, but I spend all the money on paint guns
[IMG]https://uploads.tapatalk-cdn.com/20170917/4a78a2063334c432320375e89c254059.jpg[/IMG]
[IMG]https://uploads.tapatalk-cdn.com/20170917/326dfbe8994436d63783faa40f60ca7b.jpg[/IMG][IMG]https://uploads.tapatalk-cdn.com/20170917/d412bbec796e78636afffc5483a5ea02.jpg[/IMG]
It might be overkill but I believe in the saying:
Buy the best, an cry only once.
(It is a saying in my country anyway:-)
Hi,
Just a thought/comment based on want I've been told re your water trap comment. You do need a a PROPER water tray, not just a cheap gun mounted water tray/filter. It's very easy to get moisture from the compressor into the air line and paint. The Paint then over time will 'micro blister' resulting in small imperfections in the paint finish. This applies to the primer as well as the top coat.
What paint are you using?
Hope this is helpful.
Thanks for the input john&luke
I have just sealed the car with epoxy to avoid rust on the bare metal.it is getting cold and wet around here and i am working a lot the next month.
A proper water trap will be installed before carrying on.
Paint is from Ludwig Lacke in Germany, and after epoxy it's getting higbuild polyester primer/filler, base coat and 2 pack clear. My plan is to flow coat the clear, 3 layers, hardening, sanding, then 2 more coats.
I will continue documenting progress, setbacks and lessons learned
Sent from the cold north .....
we need a like button...
hi brgdane, thanks for the info on compressors and guns, I am going to go that route from now on, I am reading with interest about your water traps etc, so keep it up. thanks again.
Setback :
Found a high spot in the left back fender, Tried to tap it down an broke the weld
I then cut a slit and welded it again. Sanded back to bare metal and now it's back to square one.
Repaired the rear panel between the lights. It had some fine cracks and a small lip had broken off.
I managed to sculpt the lip in fiberglass , looks all right now.
Started sanding the bumpers. Quite difficult as they are wobbly.
The batmobile, Black primer/filler. Todays task, 600grit wet sanding
Users browsing this forum: No registered users and 42 guests
