Mk1 NA***RESTORATION***
Re: Mk1 restoration
Postby John&Luke » Sat May 18, 2019 6:34 pm
Finished up the underside of the car today. All patched up, new seam sealer applied, rust treated and painted with anti corrosion stone chip paint.
Easy on its side rather than laid underneath it.
Then got her back on her wheels and raised the front in order to drop the sub frame for cleaning up and replacement of key components.
Good days work IMO.
Re: Mk1 restoration
Postby blackyb » Sat May 18, 2019 9:36 pm
Some serious restoration work going on here.
:mrgreen:
Re: Mk1 restoration
Postby Mazda Mender » Sat May 18, 2019 9:43 pm
:handgestures-thumbup: :coffee:
fujikun
Re: Mk1 restoration
Postby fujikun » Sun May 19, 2019 7:31 am
:text-goodpost: looks very professional. great stuff
Re: Mk1 restoration
Postby John&Luke » Wed May 29, 2019 8:28 pm
Front suspension stripped. First job top Wishbone’s . De-bushed using the treaded bar and pair of sockets approach.
Wishbones then shot blasted.
Then a coat or two of red zine oxide primer
And finally tonight a couple of coats of chassis black.
:coffee:
fujikun
Re: Mk1 restoration
Postby fujikun » Thu May 30, 2019 7:18 am
great, are you rebushing the whole car or just where necessary? what type bushes are you using?
Re: Mk1 restoration
Postby John&Luke » Thu May 30, 2019 9:48 am
fujikun wrote:great, are you rebushing the whole car or just where necessary? what type bushes are you using?
Hi mate, yes intend to change all the bushes. I have a spare set of rear wishbones and sub frame purchased from eBay that I need to bush and the rather that cut a corner and regret it later decided to do everything.
On the advice of Mm I’m going the rubber bush route. The car is for road use and hence wanted it to be compliant with our “smooth” uk roads. I understand the polybushes whilst simple to install can be very “crashie”
I’m aso intending to go the MeisterR shock route as well.
fujikun
Re: Mk1 restoration
Postby fujikun » Thu May 30, 2019 11:33 am
thanks for the info, I too will go down the standard bush route, their expensive though, meisters are not in my league.
Re: Mk1 restoration
Postby John&Luke » Sun Jun 09, 2019 1:05 pm
Found time to remove the bushes from the bottom wishbones and sand blast before priming.
Then moved on to the front subframe, sand blast, prime and then chassis black top coat.
Please with my progress.
Re: Mk1 restoration
Postby Mazda Mender » Sun Jun 09, 2019 6:29 pm
Spray or brush bud
Re: Mk1 restoration
Postby John&Luke » Sun Jun 09, 2019 7:15 pm
Mm, spray. Quick and all parts evenly coated.
Re: Mk1 restoration
Postby John&Luke » Mon Jun 17, 2019 10:39 pm
Started on my engine bay prep. Easy access with the engine and front sub frame removed.
So like all engine bays, a mix of grease, traffic film, oil, and rust.
Bit of elbow grease and the results
However, once painted it’s all got to go back together, and as I’m not the quickest at these jobs I decided a bit of time carefully labelling all the bolts, nuts, gomments, and plastic clip and making a photographic record. Finally, bolts pushed into a piece of cardboard for save keeping.
Re: Mk1 restoration
Postby GlennyGills » Thu Jun 20, 2019 8:04 pm
Attention to detail will definitely pay dividends when putting it back together.
My now ex '96 Gleneagles MeisterR Coilovers - engine bling stainless mx5parts full exhaust
Re: Mk1 restoration
Postby John&Luke » Sun Jun 30, 2019 2:49 pm
Front chassis legs, arches and front bumper mount all ready for stone chip paint. De rusted, rust converter and then etch primer and new seam sealer.
All masked up as I will gloss the engine bay later.
All protected for a few years.
Re: Mk1 restoration
Postby Mazda Mender » Sun Jun 30, 2019 9:25 pm
:text-coolphotos: :text-goodpost: :handgestures-thumbup: :coffee:
