Slacken the 17mm centre nut that holds the shocker to the top mount before undoing the 2 X 14mm and before removal, DO NOT remove the 17mm nut yet.
Remove them off the roadster.
Get the hooks on the manual compressors as close to the top and bottom as you can, and angle them on each corner.
Now these WILL be under a lot of pressure, so please be careful and use common sense.
Now you will need vice if possible to hold the damper while you use a ratchet and extension bit to compress or an air ratchet and extension bit.
Compress both compressors evenly, once compressed the top mount will become loose, undo what is left on the centre 17mm nut,remove the top mount and pull the spring free from the shocker.
Undo the manual compressors evenly, please be careful, it is under a lot of pressure, once slack and loose remove the manual compressors.
Refit as removed.
This is a quick short guide for the min, I will add full pic's and write up for removing from the roadster and removing/breaking down the shocker/damper.
Front damper/shocker
Rear damper/shocker
If you need a guide for removing from the roadster now, let me know.
For Mike A, compressing springs
