Good Morning Menders,
I have a problem with the floor of my mk3 getting wet and I think I know where the water is coming from, I just need a decent solution to stop it.
I will attach pics which will help explain further.
Mk 3 Floor Wet
Mk 3 Floor Wet
- This is typically the amound of water getting in over one nights period of rain
- IMG_8886.JPG (283.05 KiB) Viewed 28984 times
- This is the cover which holds the plastic between the bonnet and the window wipers in place (Driver Side)
- IMG_8889.JPG (220.44 KiB) Viewed 28984 times
- This is the cover on the passengers side and as you can see the screw cover has come off, I think this is where the water is getting in
- IMG_8890.JPG (257.22 KiB) Viewed 28984 times
Re: Mk 3 Floor Wet
By replacing the winscreen cowl grommet and a new grille cap I seem to have solved the leak.
Posting this for any future users who come across this thread.
I got the parts from mx5parts.
Cheers
Cheers
Re: Mk 3 Floor Wet
With this crappy weather we are having I am pleased you got it sorted.
With never having owned a Mk3, I wouldn't have known where to start, amazed a fellow Mk3 owner didn't shout up with a solution earlier.
Mended by a mender as M-m would say.
Re: Mk 3 Floor Wet
To be honest I expected a reply too,
but the best way to learn is just get to it yourself, thats what I done and it worked a treat.
Re: Mk 3 Floor Wet
I cannot be everywhere and do everything, i'm good but not that good, the leak is a common fault with the 3's , you had already solved it before i could answer so i did not see the point of replying with a repair,which most use a blob of clear sealant and screw the skuttle screw back down, but we always welcome how to's from fellow menders buddy, so thank you .
Re: Mk 3 Floor Wet
Dont worry MM, the fact you never replied meant I had to actually do a bit of research myself. Which is only a good thing.
Hopefully it can be used for reference in the furture.
Cheers
Cheers
Re: Mk 3 Floor Wet
I had seen this and had heard before about a grommet somewhere that leaks but didn't know enough to really help and I didn't want to mislead you so thought it better to not reply
Re: Mk 3 Floor Wet
I didn't know MX5parts did replacement grommets, I'll pick some up, as I had this issue also, and just used bathroom sealant to stop the leak for now.
Re: Mk 3 Floor Wet
HypnoToad wrote:I didn't know MX5parts did replacement grommets, I'll pick some up, as I had this issue also, and just used bathroom sealant to stop the leak for now.
And that is all thats needed
- Risingsun
- Serial Poster
Re: Mk 3 Floor Wet
Bit of an old thread to resurrect, but I thought I'd share a picture of the cause of the water leak in the foot wells on a MK3.
The seals around the clips that hold the windscreen scuttle panel screws perish, causing the water to leak in, the clips are cheap enough to buy from MX5 parts and replace but, to do a belt and braces job, you could always seal around the clip with some sealant to keep it water tight.
It's important to make sure you cure a leak on the passenger side as that's where the ECU resides...!!
Hope that helps.
Hope that helps.
1991 Mk1 1.6 BBR Le-Mans now sold
1994 Mk1 1.8 Import
2019 Mk4 2.0 30th Anniversary
http://www.mxfivers.com
1994 Mk1 1.8 Import
Users browsing this forum: Bing [Bot] and 14 guests
