If you have found this guide useful or any others ,and as saved you on garage costs , please drop a donation to the site, what ever you it maybe, to help keep her open and running for others to use also, many many thanks.....
This is another easy quick fix after we have had a lot of owners asking us why their mx5/roadster are whistling on journeys, which gets worse with the heater on and which is worse with an HT on although it is happening with ST also...
Well there is a number of reasons why this can be happening.
1 ) The HT or ST is not adjusted correct and needs doing so.
2 ) The header seal is toast and wants replacing.
3 ) The windscreen frame as dropped slightly from age, which becomes complicated to re shape but can be done on the drive...
So if you have checked or attacked all of the above ( bar 3) with no joy then this simple fix will cure the problem and a very satisfying outcome with the very basic of tools to cure a very annoying issue...
You will need ...
1 x utility knife or scissors,
1 x sheet of rubber 3 mm thick and 17mm long,
1 x tape measure,
1 x marker pen.
***PLEASE NOTE CLICKING ON THE IMAGES WILL ENLARGE THEM FOR BETTER VIEWING***
You will need to to cut 2 x strips of rubber 17 inches long by 20mm wide and 3mm thick, if you can cut it as one strip then please do....
Then make your way to the roadster....
Make sure the Hard top is off or the Soft top down and lift the frame header seal from out of its channel, there is no need to fully remove it( see pics).....
Then it is just simply a matter of putting the strips into the channel making sure they butt up together in the middle....
And then it is just a case of re fitting the seal , and thats it done, no more whistling at speed...
Re fit your Hard top back on ,or bring your Soft top back up to a nice snug tight seal, and go and road test her..
As always , any questions you may have please feel free to contact admin etc, its what we and the forum is for.
How to stop whistling through the header seal(Rob Barker)
